15 years ago
Difference between command and GUI builds
When I try to build with *.qxp files through the GUI, the GUI finds the qxp files with no problems. They are in a sub-dir called "qxp" under the dir that I start the GUI from. But if I use a Makefile it can not find the qxp files and errors with "undefined entity". Has anyone seen this issue before?
The Makfile works fine when not using qxp files and I use other sub-dirs in the build for *.v files.
Here is the Makefile which is taken from Altera suggestions.
PROJECT = mp_fpga
SOURCE_FILES = mp_fpga.v# ASSIGNMENT_FILES = ../scripts/mp_fpga.qpf ../scripts/mp_fpga.qsf # ASSIGNMENT_FILES = ../scripts/mp_fpga.qpf mp_fpga.qsf
ASSIGNMENT_FILES = mp_fpga.qpf mp_fpga.qsf
# ################################################################### Main Targets# # all: build everything# clean: remove output files and database# ##################################################################
all: smart.log $(PROJECT).asm.rpt $(PROJECT).tan.rpt
clean:
rm -rf *.rpt *.chg smart.log *.htm *.eqn *.pin *.sof *.pof db
map: smart.log $(PROJECT).map.rpt
fit: smart.log $(PROJECT).fit.rpt
asm: smart.log $(PROJECT).asm.rpt
tan: smart.log $(PROJECT).tan.rpt
smart: smart.log
# ################################################################### Executable Configuration# ##################################################################
MAP_ARGS = --family=STRATIXII --source=$(SOURCE_FILES)
FIT_ARGS = --part=EP2S90F1020C5
ASM_ARGS =# TAN_ARGS =
TAN_ARGS = --sdc=mp_fpga.sdc
# ################################################################### Target implementations# ##################################################################
STAMP = echo done >
$(PROJECT).map.rpt: map.chg $(SOURCE_FILES)
quartus_map $(MAP_ARGS) $(PROJECT)
$(STAMP) fit.chg
$(PROJECT).fit.rpt: fit.chg $(PROJECT).map.rpt
quartus_fit $(FIT_ARGS) $(PROJECT)
$(STAMP) asm.chg
$(STAMP) tan.chg
$(PROJECT).asm.rpt: asm.chg $(PROJECT).fit.rpt
quartus_asm $(ASM_ARGS) $(PROJECT)
$(PROJECT).tan.rpt: tan.chg $(PROJECT).fit.rpt
quartus_sta $(TAN_ARGS) $(PROJECT)
smart.log: $(ASSIGNMENT_FILES)
quartus_sh --determine_smart_action $(PROJECT) > smart.log
# ################################################################### Project initialization# ##################################################################
$(ASSIGNMENT_FILES):
quartus_sh --prepare $(PROJECT)
map.chg:
$(STAMP) map.chg
fit.chg:
$(STAMP) fit.chg
tan.chg:
$(STAMP) tan.chg
asm.chg:
$(STAMP) asm.chg
    Here is an update:
    - using quartus version 10.1
    - I run both the Makefile and the GUI in a linux environment
    - When I run "quartus_sh --flow compile mp_fpga" from a perl script it also finds the qxp dir.
    Running from a perl script solves my problem but I still would like to know why running from a Makefile fails.
    If you use a makefile, then you will need to call the exact same EXEs that "--flow" calls. Simply look at the *.flow.rpt report to learn what --flow does. Then simply emulate that from your make file.
    Hope that helps
    To be clear, I am talking about the "Flow Log" section in the .flow.rpt file. That will show you the exact commands that the internal flow used.
