16 years agoHi,
with Modelsim you can do testbench, Quartus II can't. And for the other question: --- Quote Start --- Is the ModelSim-Altera Edition software the same as the ModelSim PE or the ModelSim SE software? No, the ModelSim-Altera Edition software is licensed to support designs written in 100 percent VHDL and 100 percent Verilog language and does not support designs that are written in a combination of VHDL and Verilog language, also known as mixed HDL. Mixed HDL support is available in the PE and SE versions of ModelSim from Mentor Graphics. ModelSim-Altera Edition only supports Altera gate-level libraries. The ModelSim-Altera Edition software includes all ModelSim PE features, including behavioral simulation, HDL testbenches, and tool command language (Tcl) scripting. However, the simulation performance of the ModelSim-Altera Edition software is slower than that of the ModelSim PE and SE software. ModelSim-Altera Starter Edition software is the same as ModelSim-Altera Edition software except for two areas. ModelSim-Altera Starter Edition’s simulation performance is lower than ModelSim-Altera Edition and has a line limit of 10,000 executable lines compared to the unlimited number of lines allowed in the ModelSim-Altera Edition. --- Quote End ---
