--- Quote Start ---
Hello everyone,
I was wondering, when implementing a DFF with clock enable :
library IEEE;
use IEEE.STD_LOGIC_1164.
all;
entity D_FF_VHDL
is port ( clk :
in std_logic; rst :
in std_logic; pre :
in std_logic; ce :
in std_logic; d :
in std_logic; q :
out std_logic )
end entity D_FF_VHDL;
architecture Behavioral
of D_FF_VHDL
is
begin process (clk)
is
begin if rising_edge(clk)
then
if (rst='1')
then
q <= '0';
elsif (pre='1')
then
q <= '1';
elsif (ce='1')
then
q <= d;
end if;
end if;
end process;
end architecture Behavioral;
What happens with q when ce equals to '0'? How does the FF keeps last state? Why after q<=d line shouldn't we add :
else
q<=q?
As I understand there shouldn't be any state at which q is unknown. Hence, when the clock is rising but disabled by ce='0' state of q in unknown.
Please explain.
Much appreciated,
Boris.
Simulation Results[/B][/B]
--- Quote End ---
you can add that line if you wish but it is implied that if a condition is not defined it means it saves its last value.
