xiaobai1's avatar
xiaobai1
4 years ago
Development board outputs clock signal
I have encountered some problems in the process of learning. I sincerely hope you can spare time to guide me.
  1. Objective: To obtain 50MHz clock signal by using CycloneV (5CGTFD9E5F35) to output onboard crystal oscillator through phase-locked loop.
  2. Problems encountered at present: the phase-locked loop was called, pins were allocated and burned into the development board, but the crystal clock signal could not be obtained.
  3. General process:
(1) Input pin information found in the manual:
(2) Output pin:
Output position of the corresponding development board:
(3) RTL view and pin allocation
(4) After the program is burned into the development board, the output is connected to the oscilloscope, and the signal can not be obtained.
