10 years agoDetecting a tansition in a signal
Hi, This is my first post, hope I am doing things right I have come across a situation which completely challenges my understanding of how and when the evaluation of signals in a process takes p...
10 years agoBecause you have used <= (less than or equal) in your compare, it is comparing a single bit to a single bit with a less than doesnt really mean much. KEY(0) <= '0' is always true when KEY = '0', and PrevKey <='1' is true when PrevKey is '0' or '1', so the equation can be reduced to:
if key(0) = '0' then
counter <= counter + 1;
end if;
PS. Have you debounced your keys elsewhere? you may get several increments of counter without debouncing the key presses. As a beginner, I also recommend you get into the habit of not using std_logic_unsigned. It is a non standard VHDL package. Numeric std is the real IEEE standard.
