11 years agoDesign Suddenly Becomes Time Limited : Vendor: 0x6AF7, Product: 0x010C
I am using Quartus 14.0 & DE1-SoC.
In NIOS II / Eclipse, I generated memory initialization files:- right click application (not bsp) Make Targets -> Build.. -> mem_init_generate I then added the .qip file to quartus. When I recompile the design in Quartus II 14.0 it is now time limited! So I remove the .qip file, recompile - design is still time limited. Then I deleted the folders containing the .hex files - design is still time limited! If I look on assembler tab -> Encrypted IP cores I have 3 entries NIOS II 6AF7 00A2, Signal Tap 6AF7 BCE1 Signal Tap 6AF7 BCEC, all of status licensed. If I click programmer I get this message:- *.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x010C Any ideas welcome.
