12 years agoHave you opened up the projects to see what the error is? You need to ensure all projects are archived (not just the best). Then you can open up the individual .qar files to see what the errors are.
Make sure you have enough licences and each machine has access to the licence server. When I was running overnight seed jobs (8hr per build, 3 machines running 5 builds in parrallel at a time ~ 15 parrallel builds) I would be verry annoyed if licences ran out, as each job would finish early and end. It doesnt wait for a licence. If you run a seed value that is the same as the base compilation, that run will be ignored.
