Design Space Explorer Parallel Compilation
Why do you need to match in Quartus? If DSE is producing a result that works for you, can't you just use that generated project?
- TomCarpenter1 year ago
We version control our project, but only at the source file level because the netlists are simply too huge (several GB) to be in a git repo. Couple that with an internal need for reproducibility (assuming same version of same Quartus toolset), we need to have a single project that can be stored rather than having multiple DSE generated projects.
While yes I could set DSE running again to get the required result, that takes a day to run and find the working seed (densely packed Arria 10 SX660). I'd rather then just be able to store and compile that one seed in Quartus the future (~4hrs) if I need to reproduce the netlist.
But anyway, it's moot now, I found the issue to be that I'd added the processor limit to the Quartus file after DSE generated its archive, so the two weren't running on the same `NUM_PARALLEL_PROCESSORS` setting.
