Design Space Explorer Parallel Compilation
The number of CPUs is the number of core processor detected on your local machine, that you can use, to perform the number of parallel compilation that you set.
Example. no. of CPU - 4; no. of parallel compilation - 2 : The DSE tool will use 2 core processor to run 4 compilations parallel.
And if you set no. of seed to 10, it will run 4 compilation first, then another 4, and lastly 2.
Take note that* Performing more than one compilation requires significant computing power, memory resources, and additional Quartus Prime licenses.
You may checkout this youtube video for further information.
https://www.youtube.com/watch?v=1cc74E3zaeI
Richard Tan
- TomCarpenter1 year ago
Hi Richard,
I'm using Quartus 22.1, and trying to get DSE II and Quartus to match up (i.e. DSE gives me a fitter seed that works, after searching through several), but if I then apply that seed to the source project in Quartus and run the fitter, I get different results.
Having read another thread on this forum, they said that you have to make sure that the maximum number of processors used in DSE matches the maximum number set in Quartus as that has an impact on the fitting process.
In DSE, I'm using no of CPU = 24 and no parallel = 6. From your description, that should mean that each compile uses a maximum of 4 processors per seed. I had set the max of 4 in Quartus project, but compiling that, I still get different results.
I've opened one of the DSE generated project copies, and notice that the Fitter settings that DSE applied to the project are shown as:
So that seems to suggest that the no of CPU setting is per seed run and not total number.
Would you be able to double check whether this is correct?
I'll try running again with DSE tomorrow with it set to no CPU 4 and see if they start to line up.
Ok, found the problem. The `set_global_assignment -name NUM_PARALLEL_PROCESSORS 4` was missing from the QSF files that DSE was testing on. Because I added it after generating the QAR that DSE was using, the two were producing different results - I'd assumed it would be added but obviously that was a bad assumption.
Running DSE again with the assignment produces matching results between Quartus and DSE which is what I need.
