18 years ago --- Quote Start --- No problem. Can I ask what platform you're running Quartus II under? Windows? Linux? If you hit play twice in the Quartus II GUI do you get the same results? If you just do a seed sweep in DSE (see the effort level to Low) is the best seed result found by DSE reproducible in the Quartus II GUI ? --- Quote End --- Yes I'm running QII in Windows XP, QII surely get the same results if I compile my project again and again cause it won't really compile anything when I click the play the second time:p In fact I think the QII itself is much more stable compare to v7.1, seem the only problem is there are some misunderstanding when it's DSE talk to the compiler... I haven't try the low effort level, I'll try now.
