12 years ago --- Quote Start --- You don't need to do any major work. Just check one single case to see which tool is not telling the truth. I expect the one that tells you is right and the one that didn't was not efficient enough. --- Quote End --- I did it for some of such issues: it seems in all cases related to data transfer between two different clock domains, both generated by the same PLL, 160MHz and 40MHz. Aren't the two generated by same PLL synchronous?
