Design Assistant -> recommended flow
Hi All,
What's the recommended flow for using the Design Assistant? Does it worth to enable it running automatically during each flow run or probably better execute it manually after the flow has already been completed?
Is running the Design Assistant automatically time-consumed task? How much could it increase the compilation time?
What rules of the Design Assistant are critical and should be ALWAYS checked?
How could I know what Design Assistant rules should I check?
1 Reply
- Nurina
This seems like a duplicate of this thread: https://community.intel.com/t5/Intel-Quartus-Prime-Software/Design-Assistant-amp-gt-recommended-flow/m-p/1424337#M75701
I will close this case and respond on the above thread.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Thank you,
Nurina
