amildm
Contributor
3 years agoDesign Assistant -> recommended flow
Hi All,
What's the recommended flow for using the Design Assistant? Does it worth to enable it running automatically during each flow run or probably better execute it manually after the flow has ...
Nurina
3 years agoHi,
This seems like a duplicate of this thread: https://community.intel.com/t5/Intel-Quartus-Prime-Software/Design-Assistant-amp-gt-recommended-flow/m-p/1424337#M75701
I will close this case and respond on the above thread.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Thank you,
Nurina
