11 years agoDelays and glitches in simulation
I wonder if I misunderstand something or the Qartus simulation is not able to consider state changes I want to display. I started with the Quartus demo program 'light'. I noticed that the change in the output signal 'f' occurs cca 1.3 ns after the change in the input signal. Although there is a little difference in the transition time between the 0->1 and 1->0 transitions, there is no effect visible in the output signal 'f'. I intended to increase this difference, so I inserted 4 more inverters on one signal path.module lights(x1, x2, f, dummy);
input x1, x2;
output f, dummy;
wire x1i/* synthesis keep */;
wire x2i /* synthesis keep */;
wire x12or /* synthesis keep */= x1 | x2;
assign x1i = ~x1;
wire x21 = ~x2 /* synthesis keep */;
wire x22 = ~x21 /* synthesis keep */;
wire x23 = ~x22 /* synthesis keep */;
wire x24 = ~x23 /* synthesis keep */;
assign x2i = ~x24;
assign f = (x1 & x2i)|(x1i & x2);
assign dummy = x12or;
endmodule
According to the wave diagrams, 0->1 transition needs 1.5 ns, the 1->0 transition needs 1.6 ns. However, the transition following the 1->0 transition needs only 0.4 ns. The 5 inversions require altogether 3 ns time, both for 1->0 and 0->1 transitions. This exceeds my knowledge in arithmetics. Also, I produced signal 'dummy' just to find out the time consumption of ORing and outputting a signal. This is 4.8 ns. The 5 times inverted signal produces a change in 6.4 ns, so I conclude that the 5-times inversion takes some 1.6 ns, which is about the time of one-time inversion, and the half of the time needed to produce the 5-times inverted signal. I am really confused. :confused: In this way, the time difference between the appearance of the two inverted signals on the OR gate is in the order of the operation of a gate. So, I expected that during this transient period there will be a "glitch" in the signal 'f', but according to the wave diagram, there is no such glitch. Should it be? (I include also my vwf file) HEADER
VERSION = 1;
TIME_UNIT = ns;
DATA_OFFSET = 0.0;
DATA_DURATION = 200.0;
SIMULATION_TIME = 0.0;
GRID_PHASE = 0.0;
GRID_PERIOD = 10.0;
GRID_DUTY_CYCLE = 50;
USER_TYPE("__bvc")
VALUES = "Undefined";
SIGNAL("x1")
VALUE_TYPE = NINE_LEVEL_BIT;
SIGNAL_TYPE = SINGLE_BIT;
WIDTH = 1;
LSB_INDEX = -1;
DIRECTION = INPUT;
PARENT = "";
SIGNAL("x2")
WIDTH = 1;
LSB_INDEX = -1;
DIRECTION = INPUT;
PARENT = "";
SIGNAL("f")
WIDTH = 1;
LSB_INDEX = -1;
DIRECTION = OUTPUT;
PARENT = "";
SIGNAL("x1i")
WIDTH = 1;
LSB_INDEX = -1;
DIRECTION = COMBINATORIAL;
PARENT = "";
SIGNAL("x2i")
WIDTH = 1;
LSB_INDEX = -1;
PARENT = "";
SIGNAL("x21")
WIDTH = 1;
LSB_INDEX = -1;
PARENT = "";
SIGNAL("x22")
WIDTH = 1;
LSB_INDEX = -1;
PARENT = "";
SIGNAL("dummy")
WIDTH = 1;
LSB_INDEX = -1;
DIRECTION = OUTPUT;
PARENT = "";
TRANSITION_LIST("x1")
NODE
REPEAT = 1;
LEVEL 0 FOR 100.0;
LEVEL 1 FOR 90.0;
LEVEL 0 FOR 10.0;
TRANSITION_LIST("x2")
NODE
REPEAT = 1;
LEVEL 0 FOR 50.0;
LEVEL 1 FOR 50.0;
LEVEL 0 FOR 50.0;
LEVEL 1 FOR 50.0;
TRANSITION_LIST("f")
NODE
REPEAT = 1;
LEVEL X FOR 200.0;
TRANSITION_LIST("x1i")
NODE
REPEAT = 1;
LEVEL U FOR 200.0;
TRANSITION_LIST("x2i")
NODE
REPEAT = 1;
LEVEL U FOR 200.0;
TRANSITION_LIST("x21")
NODE
REPEAT = 1;
LEVEL U FOR 200.0;
TRANSITION_LIST("x22")
NODE
REPEAT = 1;
LEVEL U FOR 200.0;
TRANSITION_LIST("dummy")
NODE
REPEAT = 1;
LEVEL U FOR 200.0;
DISPLAY_LINE
CHANNEL = "f";
EXPAND_STATUS = COLLAPSED;
RADIX = Binary;
TREE_INDEX = 0;
TREE_LEVEL = 0;
DISPLAY_LINE
CHANNEL = "dummy";
RADIX = Binary;
TREE_INDEX = 1;
TREE_LEVEL = 0;
DISPLAY_LINE
CHANNEL = "x1";
RADIX = Binary;
TREE_INDEX = 2;
TREE_LEVEL = 0;
DISPLAY_LINE
CHANNEL = "x1i";
RADIX = Binary;
TREE_INDEX = 3;
TREE_LEVEL = 0;
DISPLAY_LINE
CHANNEL = "x2";
RADIX = Binary;
TREE_INDEX = 4;
TREE_LEVEL = 0;
DISPLAY_LINE
CHANNEL = "x2i";
RADIX = Binary;
TREE_INDEX = 5;
TREE_LEVEL = 0;
DISPLAY_LINE
CHANNEL = "x21";
RADIX = Binary;
TREE_INDEX = 6;
TREE_LEVEL = 0;
DISPLAY_LINE
CHANNEL = "x22";
RADIX = Binary;
TREE_INDEX = 7;
TREE_LEVEL = 0;
TIME_BAR
TIME = 100000;
MASTER = TRUE;
