13 years agoThanks for the fast reply
--- Quote Start --- for a start, are you sure the data will be aligned correctly? you need to make sure the data is set up 2 clock cycles before the enable is high to ensure that the setup time wont be violated with these slack paths. Yes, I guarantee the data alignment. It might be easiest to just tell it to look for all registers in the path with wildcards: set_multicycle_path -from [get_keepers {ent_name:inst_name|my_slow_entity:slow_entity_inst|*}] -to [get_registers {ent_name:inst_name|my_slow_entity:slow_entity_inst|*}] -setup 3 set_multicycle_path -from [get_keepers {ent_name:inst_name|my_slow_entity:slow_entity_inst|*}] -to [get_registers {ent_name:inst_name|my_slow_entity:slow_entity_inst|*}] -hold 2 This will then only get applied to valid paths - any connections that dont exist will be ignored (so if you have the registers A -> B -> C, it wont set up a path from A -> C because that connection doesnt exist). Would U please rewrite the constraint with the specified hierarchy in my first post ? I just got confused just reading the syntax. I'm using VHDL, the instant name is fpu1 and the instantiated module is fpucorr => fpu1 : fpucorr
port map (
....); Also I have other questions: Will the wildcards make the constraint propagate inside the fpu1 hierarchy ? Why did U choose 3 for setup and 2 for hold ? --- Quote End --- Thanks in advance
