13 years ago
Declaration ?
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.ALL;
entity uppgift_3b is
port
clk : in std_logic; -- CLOCK_50
-- RAM
addr_ram : in std_logic_vector(2 downto 0); -- addr in slide switches
data_ram : in std_logic_vector(1 downto 0); -- data in slide switches
we_ram : in std_logic; -- from slide switches
q_ram : out std_logic_vector(1 downto 0); -- data out to leds
---ROM
addr_rom : in std_logic_vector(1 downto 0); -- addr in slide switches
q_rom : out std_logic_vector(1 downto 0) -- data out to leds
end entity;
architecture BLOCK_RAM_ROM_FPGA OF uppgift_3b IS
---- RAM
TYPE rom_type IS ARRAY (0 TO 63)OF
std_logic_vector (2 downto 0);
SIGNAL RAM_mem: mem_type; ----- < (*) i must declare this i dont know how ? -----
--- ROM
TYPE rom_type IS ARRAY (0 TO 3**2 - 1) OF STD_LOGIC_VECTOR (2 DOWNTO 0);
CONSTANT ROM_mem: rom_type := (
"111", -- adr 0
"000",
"101",
"100",
"010",
"110",
"100", -- adr 6
OTHERS => "000");
BEGIN
RAM: PROCESS (clk)
BEGIN
IF rising_edge(clk) THEN
IF (we_ram = '1') THEN
RAM_mem(conv_integer(addr_ram)) <= data_ram;
END IF;
q_ram <= RAM_mem(conv_integer(addr_ram));
END IF;
END PROCESS;
----------------------------------- ROM ----------------------
ROM: PROCESS (clk)
BEGIN
IF rising_edge (clk) THEN
q_rom <= rom_mem(conv_integer(addr_rom));
END IF;
END PROCESS;
END ARCHITECTURE Block_RAM_ROM_FPGA;
(*)Error (10482): VHDL error at uppgift_3b.vhd(25): object "mem_type" is used but not declared
1 Reply
    You have declared two different types for the same name. (rom_type is declared twice)
    Change the first to:
    TYPE ram_type IS ARRAY (0 TO 63) OF std_logic_vector(2 DOWNTO 0);
    and then declare your ram as:
    SIGNAL RAM_mem: ram_type;
    Hope this helps
