12 years agoDecision scheme
Hi ,
I design decision scheme in order to determine whether the signal i '0' or '1' from group of 4 bits and then the output signal of the scheme change respectively . for some reason the output signal Des_out is persistently '0' . The VHDL code is : --process - decision scheme '0' or '1' process (ResetP) variable score : integer range 1 to 4; begin score := 1 ; if ( resetP = '1' ) then Des_out <='0'; elsif ( clk_100M'event and clk_100M='1' ) then for ind in 0 to 3 loop if hlp(ind)='1' then score := score + 1; end if ; end loop ; if (score > 2) then Des_out <= '1'; else Des_out <= '0'; end if ; end if ; end process; what is wrong in the design ?why does Des_out is consistently '0' ? does the design have to be depend in the clock event or it will change for every change in the group of 4 bits ? how can i watch at variable score and ind during the simulation ? Visio file attached - look at Desicion scheme (the rest is at other process) . wave photo attached - Des_out = '0'
