12 years agoFor those of you affected by this, can you double check to see if you installed the 13.1 update 4 OpenCL SDK over the previous 13.1 installation. I suspect what might have happened is that the tools were installed to a different directory and as a result the SDK is not updated as intended. The update installer lets you install to any location on your file system so this scenerio is possible to run into.
