13 years ago --- Quote Start --- Actually I did pin assignment by import the DE2_pin_assignments.csv. It did work when I applied on Quartus 10.1 Actually I did try to assign the pins manually with pin planner. And, it did work. I wonder whether the .csv file I used is not compatible with the Quartus 12.1 --- Quote End --- You should be able to check with the Pin Planner whether the assignments for those two signals are correct. Cheers, Dave
