16 years agoI have the same problem with quartusII 7.2..
--- Quote Start --- 1) load the .sof manually using programmer tool. 2) use nios2 shell command :"H:\altera\90\nios2eds\Nios II Command Shell.bat" 3) in this console window, go to the Control_panel directory (the path hase the form /cygdrive/<niosdrive/..... 4) execute : nios2-download DE2_70_Control_Panel_ssram.elf -c USB-Blaster[USB-0] -r -g 4 remark) I can put this line in file (example toto) and after call "bash toto" in the console. --- Quote End --- couldnät understant step 4
