DDR3 Controller for Micron Part no MT41K512M8RH-125E
Hi, we are using bittware S5PHQ- PCI Ethernet card. it has stratix V device and micron DDR3. In Quartus ver 15.1 , we couldn't find the DDR3 controller for micron part no MT41K512M8RH-125E. Quartus support max MT41(k/J)256* series. is any alternate controller for this part no.
what is solution for this
- Deshi_Intel
HI,
I presume you are referring to the Micron preset available the UNIPHY DDR3 IP.
There is no way for DDR3 IP to list down preset for all available SDRAM vendor and type in the market.
So, the workaround will be to check out the DDR3 SDRAM datasheet and key in the SDRAM parameter in the DDR3 IP manually.
dlim
- kanthi
Hi Thank you for your mail. I will try and update to you if any issue Thanks sivakumar
- Deshi_Intel
Alright :)
- Deshi_Intel
Hi sivakumar,
I am setting this case to closure first as it's idle for long time.
Feel free to take your time to debug and you are always welcome to file new case later to resume the discussion.
dlim
