16 years agocycloneIII I/O error in Quartus 9.1 while cycloneII succeed.
I use alt_inbuf with cycloneIII got this error:
--- Quote Start --- Error: The location assignment on the I/O primitive instance "pad_in_pullup_cell_01" specifies an exact pin location. This is not supported for the Cyclone III family in the current version of the Quartus II software. File: /home/write-able/3/src/top.v Line: 20 --- Quote End --- If I change to use a cycloneII, all OK. Does anyone know why ? https://www.alteraforum.com/forum/attachment.php?attachmentid=1651 https://www.alteraforum.com/forum/attachment.php?attachmentid=1652 --- Quote Start --- //------------------------------------------ //------------------------------------------ //------------------------------------------ //------------------------------------------ module pad_in ( SPAD, in_inside ); input SPAD ; output in_inside ; //------------------------------------------ wire SPAD ; wire in_inside ; //------------------------------------------ alt_inbuf pad_in_pullup_cell_01 ( .i ( SPAD ), .o ( in_inside ) ); defparam pad_in_pullup_cell_01.io_standard = "3.3-V LVCMOS" ; defparam pad_in_pullup_cell_01.location = "PIN_149" ; defparam pad_in_pullup_cell_01.enable_bus_hold = "off" ; defparam pad_in_pullup_cell_01.weak_pull_up_resistor = "off" ; defparam pad_in_pullup_cell_01.termination = "NONE" ; endmodule //------------------------------------------ //------------------------------------------ //------------------------------------------ //------------------------------------------ module pad_out ( SPAD , out_inside ); output SPAD ; input out_inside ; //------------------------------------------ wire SPAD ; wire out_inside ; //------------------------------------------ alt_outbuf pad_out_cell_01 ( .o ( SPAD ), .i ( out_inside ) ); defparam pad_out_cell_01.io_standard = "3.3V LVCMOS"; //defparam pad_out_cell_01.location = "MAXIMUM CURRENT"; //defparam pad_out_cell_01.location = "PIN_87" ; defparam pad_out_cell_01.enable_bus_hold = "off"; defparam pad_out_cell_01.weak_pull_up_resistor = "NONE"; //defparam pad_out_cell_01.termination = "series 25 ohms"; defparam pad_out_cell_01.termination = "NONE"; defparam pad_out_cell_01.slew_rate = -1; defparam pad_out_cell_01.slow_slew_rate = "NONE"; endmodule //------------------------------------------ //------------------------------------------ //------------------------------------------ //------------------------------------------ module top ( in , out ); output out ; input in ; //------------------------------------------ wire out ; wire in ; //------------------------------------------ wire ww1 ; //------------------------------------------ pad_in pad_in01 ( .SPAD ( in ) , .in_inside ( ww1 ) ); pad_out pad_out01 ( .SPAD ( out ) , .out_inside ( ww1 ) ); endmodule //------------------------------------------ //------------------------------------------ //------------------------------------------ //------------------------------------------ --- Quote End ---
