NJackson's avatar
NJackson
4 years ago
Cyclone V IOB Register Packing
Warning (176225): Can't pack node OEM_Prototype_Top_Level:TOP_LEVEL|TX_Signal_Path:TX_Signal_Path_inst|Stave_ADC_CTRL:IIU_ADC_CTRL_inst|LTC2380_CTRL:\CHANNEL:1:LTC2380_CTRL_INST|adc_sr[0] to I/O pin
Warning (176229): Can't pack node OEM_Prototype_Top_Level:TOP_LEVEL|TX_Signal_Path:TX_Signal_Path_inst|Stave_ADC_CTRL:IIU_ADC_CTRL_inst|LTC2380_CTRL:\CHANNEL:1:LTC2380_CTRL_INST|adc_sr[0] and I/O node IIU_MISO -- nodes have conflicting location assignments
Info (171110): Nodes could not be merged because their location constraints do not overlap
I am trying to force Quartus to use Fast Input Register on an input to my design using the Fast Input Register assignment. However, when I build my project I get the warnings in the code snippet. When I inspect the Resource Property Editor, I can see that Quartus has not used the IOB Fast Input Register.
Clearly there's something I'm not taking into account so how can I enable the Fast Input Register?
  • sstrell's avatar
    sstrell
    What are your inputs connecting to? If they are connecting to some hard resource on the device that has its own input registers, then you have a conflict between the use of the registers in the I/O cell and the registers in the hard resource.
    If not that, do you have other physical location constraints, like Logic Lock regions?
    • NJackson's avatar
      NJackson
      My input is connecting to a Shift Register instantiated using HDL.
      There are no location constraints except for a pin assignment.
  • AminT_Intel's avatar
    AminT_Intel
    We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
