12 years agoCyclone V DDR3 Controller with Uniphy
I am new with qsys and memory configurations and was wondering if someone could please point me in the right direction. When I generate the DDR3 controller in qsys I get an input called "oct_rzqin" that I do not know what to do with. The DDR3 that I am using (MT41J256M8) has a ZQ pin that is routed to a 240 ohm resistor and then to ground as the spec sheet calls for. It seems like the FPGA oct_rzqin pin is trying to serve the same purpose but I cannot find anywhere if this is necessary or how to properly use it. The design will not compile if this pin stays unconnected. Thanks.
