CYCLONE IVE ODDR delay mismatch
- 5 months ago
The routing delay difference due to different type of pin assigned.
The bit fpga_dac_CHA[3] using this type of pin:
While other bits using these type of pin:
Different pin type will have different internal routing delay and this is fix one which cannot be changed.
So if change bit fpga_dac_CHA[3] and fpga_dac_CHB[3] pins to for example PIN_115 and PIN_120. The timing will be similar for all bits:
I'm still unsure about the false path issue. I can't figure out why I should disable the path between the falling edge of launch-clk and the rise edge of latch-clk. The launch-clk for oddrs could also be the falling one, since it's a ddr.
I believe cblixt1 is talking about the source synchronous constraint. You may refer to this link https://docs.altera.com/v/u/docs/653688/an-433-constraining-and-analyzing-source-synchronous-interfaces
