18 years agoCyclone III rup signals
The Pin Connection Guideline for Cylone III recommends rup signal be tied to VCCIO. I've tied all other unused IO to GND. I'd like to simple use the setting for unused pins in Quartus to "as outputs driving ground" to improve noise. Will this setting cause the rup pin to driven to ground and thus causing a short to this IO pin because I have tied it to VCCIO? If so, how do I tie rup to VCCIO as recommended and still set all unused pins to driving ground without issue?
