15 years agocyclone altpll max freq?
I am using cyclone ep1c20 grade 8, with an external clock 27M.
The altpll provides two clock outputs, 135M (c0) and 405M (c1 = 27x15). and 405M is to be used as a sampling clock for signal tap. However, compilation fails at fitter, error message reads, "port clk1 output freq of 405M for PLL must be in range of 15.3-275MHz". Why it is so small? If that is the case, how to achieve a LVDS link with throughput > 275Mbps? manual says cyclone could achieve 640Mbps in LVDS. Thanks.
