Cyclone - and QuartusII 13
I found in the download file list at altera.com that Quartus II version 13.0 SP1 supports Cyclone (without II and higher as suffix)
I still have a development board with a Cyclone and a JTAG interface, so right now I want to explore it. Also downloaded the accompanying cyclone-13.0.1.232.qdz file that should incorporate the Cyclone data. However Cyclone II is the lowest family that shows up?6 Replies
It looks like Cyclone and Cyclone II were phased on in Quartus II v13.1. All versions prior to that should support the Cyclone family, including 13.0 SP1. I have 13.0 sp1 installed and can confirm that the Cyclone family is supported. If you go into the Assignments -> Device menu you can select Cyclone as Device Family.
The Cyclone family is present but the lowest device series is type CycloneII and I am looking for the Cyclone series. Call it Cyclone I but actually the name is Cyclone. It is the series devices that was marketed before the Cyclone II.
Here is a screenshot that shows that it is not in the .qdz file, as far as I understand. - Altera_Forum
Just downloading the device support file isn't enough. See the Quartus installation guide for instructions on how to install the device support file.
--- Quote Start --- The Cyclone family (gen 1) is supported in Quartus II 13.0sp1. See attached screen shot. Maybe you need to go back through the install process to enable that family. --- Quote End --- Thanks for answers. The solution shows up as following: The log file of installation reports that everything went OK. After a search I found out with the Software Selector that version 13.0SP1 of Quartus 2 covers cyclone I, as you showed above, BUT NOT in the free web version that I am using. http://www.alteraforum.com/forum/attachment.php?attachmentid=12355&stc=1 Looking downwards in the selector it turns out that version 11.0 is the highest version of Quartus-2 free lite webversion that includes the cyclone! in the cyclone family of devices. http://www.alteraforum.com/forum/attachment.php?attachmentid=12356&stc=1 Thanks for your cooperation. - Altera_Forum
--- Quote Start --- After a search I found out with the Software Selector that version 13.0SP1 of Quartus 2 covers cyclone I, as you showed above, BUT NOT in the free web version that I am using. --- Quote End --- That's unfortunate, and pretty odd. I have no clue why Altera would do that, but I'm 100% certain their reasons are irrefutable (not!). Good job figuring this out.
