13 years ago --- Quote Start --- I have a text file with 10^9 bits that I would like to introduce as my pattern. Is it possible with a dual-port ram introduce that number of bits? How would I be able to read the text file and introduce them as my input bitstream? --- Quote End --- 10^9 = 1Gbit, is about 1000x too big for on-chip RAM. However, it is only 128MB which is not bad for DDR memory. Ultimately it depends on what your hardware has to offer. Regarding using Avalon-MM/Avalon-ST RAM components, I have recently updated a tutorial that contains these components; http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104paper_hawkins.pdf The PDF has links to the code. Cheers, Dave
