13 years agoSorry, I don't have time to help you design your system. You just have to take the time to understand all the concepts.
Ignore your design for the moment, and decide what components you need. Create those components and instantiate them in a Qsys system with the verification IP test components. Write a Modelsim simulation and check your components work. Only then can you add them to a system. Once you create a system with Altera and your IP, then create a testbench and test it. The key is to get everything working in Modelsim first. In Modelsim you have much better visibility into the design. If you cannot get things to work in Modelsim, what chance do you have of getting it to work in real hardware? Cheers, Dave
