13 years agoIn my current design, the pattern_out of the pattern generator is connected to a timing_adapter and the out of the timing adapter is connected tx_parallel_data of the low_latency protocol. This is a design for a "Transceiver Toolkit". But now I have replaced the pattern generator by an on-chip RAM but actually I don't know very well how I should to connect the RAM in this design. I attached my current qsys system in order to make more understandable.
Maybe should I change my design? Thank you for your help.
