15 years agoThanks Chris. I was able to make the component at the top level using your instructions, and it even has i/o ports! I was using an external editor and did not realize that I needed to use the internal editor to convert Verilog into a placeable component. As you can tell, I am still a Quartus n00b. :)
I have a large SOPC block in my design that contains a NIOS II, memory, and many other components that work great. I had originally tried incorporating my custom Verilog into that system, but again my conduits did not result in additional i/o ports on the SOPC "brick" back in my Quartus schematic. Am I misunderstanding the meaning of conduits? I'm sure this will come up in the future. Thanks again for you quick, correct, and most helpful response! LH
