--- Quote Start --- :o I use quatus2 8.1 software, in the time when custom rom , mif file content changes, and can not output the data I want.I can't find the reason.it's terrible! --- Quote End --- Hi, can you specify what output you expect and post the MIF-File your are using. Kind regards GPK - Altera_Forum
Do you mean you MIF file is modified ? Quartus V8.1 has such a bug that it modifies custom MIF files. Only workaround known so far is to change the file attribut for this MIF file to read only by using the normal file explorer of your OS.
it looks like this is the solution MSchmitt is referring to:
http://www.altera.com/support/kdb/solutions/rd02242009_166.html - Altera_Forum
Thanks!I had done as your words.It's helpfull.
