Current Programming Hardware Does Not Support Active Serial Programming
I'm using Quartus II 10.1 with ByteBlaster II cable to program an Altera CPLD, EPCS4S18, using a *pof program. The CPLD is mounted on a PCB with power coming from the logic cage. Everything seems Ok but when I click-on "Start," it always give me an error message - " Current programming hardware does not support Active Serial Programming programming." The parallel printer cable and the ByteBlasterII download cable are verified good. I tried programming both brand new boards and old board as well as different logic cage but with the same result.
Any idea what's causing this problem?3 Replies
Do you mind showing a screenshot of your programmer window? Is the programmer in JTAG mode? :)
I'm sorry for the delayed response. We're shutdown for 2 weeks during the holidays and as usual, heavy workload upon return to work. As for programming mode, I'm using the Active Serial Programming. Strange, I don't see the original error message now when I click-on "Start" but instead getting the "Failed" message, nothing else.
