14 years ago --- Quote Start --- A 27Mhz clock and 100Mhz clock are not synchronous to each other. You have to cut timing between them, as there's no way the edges will consistently align. Your design either needs to be able to handle that, or you need a circuit that allows the data to go between(hand-shaking, dual-clock FIFO, etc.) --- Quote End --- ? you mean I can ignore this warning?or use the key word "set timing cut assignment"?
