8 years agoCritical warning about asynchronous clock domains from same PLL
Hey there, I have an FPGA design where a part is running at 150MHz and one part is running with 75MHz (both sourced from the same PLL). So, IMHO the clocks should be synchronous. Of course...
8 years ago --- Quote Start --- My guess is that the warning are not related to PLL clocks but some other clocks in your design --- Quote End --- To my understanding I have no further clocks beside the two clocks from the PLL and my clk from the external crystal (only used for the PLL). In the compilation report under 'Design Assistant - High Violations' I get a lot of messages (see attachment). In my opinion it is definiteley a problem with the two PLL clocks since the source and destinations nodes are related to the PLL clocks.
