8 years agoCritical warning about asynchronous clock domains from same PLL
Hey there, I have an FPGA design where a part is running at 150MHz and one part is running with 75MHz (both sourced from the same PLL). So, IMHO the clocks should be synchronous. Of course...
8 years ago --- Quote Start --- Can you post the clocks report from TimeQuest or the output of write_sdc -expand? --- Quote End --- Here is the output of the write_sdc -expand command: https://pastebin.com/dhefpn2e AFAIK the negative max input/output delays are to prevent timing errors regarding the input and output pins (the FPGA runs completely asynchronously to the input and output signals).
