For Rysc =>
here the report_timing file , this design has been routed with the speed option and the result is worst than with the balanced option ....
--- Quote Start ---
Routing is very, very seldom the problem. That doesn't mean it's not a large part, but the placement is usually the culprit. For obvious reasons, a spread out placement will cause long routes. (And to be honest, a spread placement is usually caused by a spread design, i.e. something like a mux that might feed multiple components in a device).
Can you list the path details of placement and routing(from TimeQuest, do report_timing with the -file "file.txt" option), or make your own if using TAN. Also, right-click on the path in TimeQuest, Locate -> Chip Planner, and then click the Expand button to see the actual routing. I'm curious if it's pretty much the Manhattan Distance, or pretty close. (Again, routing is almost always good, which is why this is strange). That's at least a good starting point...
--- Quote End ---
