18 years agoHave you given TimeQuest timing constraints? If you are working with the TimeQuest GUI, there are canned reports in the Tasks pane (double click them to run them), some of which include clock setup. You must have constraints before the reporting commands will display anything.
If you have not constrained your clocks and have a PLL, you can start with "derive_pll_clocks -create_base_clocks". See the documentation to learn how to fully constrain your design.
