15 years agoYou could do this with floating Logic Lock Regions, but the Fitter does a much better job in Quartus II, so you will likely find that this is not necessary to meet timing. If you find that this is not the case for your design, you may be better off trying to overconstrain these paths with set_max_delay timing constraints.
