17 years agoThanks -
I have tried that but SOPC gives warning like.... m0 Must have address signal. Which address signal is it talking about? The signals going to the Avalon slave dram controller or the signal going to my external cpu? Perhaps you could clarify the signals.. My external address bus is in the Name column, what should be in the Interface column? There is a drop down with many options, should this be the export_0 option?
