17 years ago
creating a vhdl package in quatus II 6.1 web ed.
hi,
im a newbie by using quartus II and also vhdl code,
im reading a book is CIRCUIT DESIGN IN VHDL to learn :)
i need to implement the vhdl code in quartus II, im confused by compiling the vhdl package
am i create a library in C:\altera\61\quartus\libraries ? or just add the package in Project>Add/Remove Files in Project.
could you help me?:confused:
and if there is a tutorial that is using vhdl with vhdl package in quartus II,it will be helpful for me.
this is the package(mult_package.vhd)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
PACKAGE pack IS
FUNCTION mult(a,b:UNSIGNED) RETURN UNSIGNED;
END pack
PACKAGE BODY pack IS
FUNCTION mult(a,b:UNSIGNED) RETURN UNSIGNED IS
CONSTANT max: INTEGER :=a'LENGTH + b'LENGTH - 1;
VARIABLE aa: UNSIGNED (max DOWNTO 0):=
(max DOWNTO a'LENGTH =>'0')
& a(a'LENGTH-1 DOWNTO 0);
VARIABLE prod: UNSIGNED(max DOWNTO 0):=(OTHERS => '0');
BEGIN
FOR: IN 0 TO a'LENGTH-1 LOOP
IF (b(i)='1') THEN prod:=prod+aa;
END IF;
aa:= aa(max-1 DOWNTO 0) & '0';
END LOOP;
RETURN prod;
END mult;
END pack;
and the main code (multiplier.vhd)
LIBRARY ieee;
USE work.mult_package.all;
ENTITY multiplier IS
GENERIC (size: INTEGER := 4);
PORT (a,b:IN UNSIGNED(size-1 DOWNTO 0);
y:OUT UNSIGNED(2*size-1 DOWNTO 0));
END multiplier;
ARCHITECTURE behaviour OF multiplier IS
BEGIN
y<= mult(a,b);
END behaviour;
im confused about using the libraries were created
there are the steps that i did.
created a project named multiplier then
write these two in text editor
then i add these in project>add/remove files in project
then start compilation
these errors belongs to mult_package.vhd file
Error (10500): VHDL syntax error at mult_package.vhd(7) near text "PACKAGE"; expecting ";"
Error (10500): VHDL syntax error at mult_package.vhd(8) near text "IS"; expecting ";"
Error (10500): VHDL syntax error at mult_package.vhd(14) near text "BEGIN"; expecting "end", or a declaration statement
Error (10396): VHDL syntax error at mult_package.vhd(21): name used in construct must match previously specified name "pack"
Error (10523): Ignored construct pack at mult_package.vhd(4) due to previous errors
Error (10500): VHDL syntax error at mult_package.vhd(22) near text "END"; expecting "entity", or "architecture", or "use", or "library", or "package", or "configuration"
thank you.
    1. An error message ending with expecting ";" usually exactly means, you forgot a ";".
    2. As with many other programming languages, succeeding errors should be reviewed after correcting the first.
    3. The correct package reference would be in your case
    LIBRARY work;
    USE work.pack.all;
    4. As you already found out, project specific package code normally would be placed in the project directory.
    thank you for your help.
    --- Quote Start ---
    LIBRARY ieee;
    PACKAGE pack IS
    END pack;
    VARIABLE aa: UNSIGNED (max DOWNTO 0):=...
    --- Quote End ---
    i just forgot one ";" near END pack
    and that will solve the 4 of the errors then
    i change my package name as my_pack also in the code PACKAG my_pack;
    the PACKAGE name must be the same name of the file. i found it:) cheers
    these are solve my problems :)
    thank you for your interest
    Alternatively, the function could be defined in main code declarative part. It's not generally necessary to define a package to use a function.
