15 years agoMake sure you are using the Timequest analyser instead of the classic timing analyser in your project, it will probably be more efficient.
In the Tolls menu you have an 'Advisors' submenu. Into in, run the Timing Optimization advisor. It will have a look at your project and can suggest a few things to increase your fmax.
