13 years ago --- Quote Start --- Hello all, I am trying to do as much as possible with the commandline and tcl scripts. Now I know it is possible to create some already defined component with the megawizard, but I don't know how to create this component without the wizard. I have found the tcl files and a Verilogfile, but I don't think i should change the Verilog file myself. How do I know which information I should transfer to where? For Example I am trying to use the pll and give it two output clocks, how do I define these clocks? Greetings, ZeMoi --- Quote End --- I hope I understood your question. If all output clocks of the Pll were enabled, when generating the Pll with the Megawizard, you can change the Verilog. I think you just have to find the according lines and write the clk-frequency and phase shift that you need. Best way is to generate for example several plls with the megawizard and compare the verilog/vhdl files.
