16 years agocreate generated clocks
In my system, there are a few clocks. I attach its extraction below, where clk1(50MHz) and clk0(100MHz) are irrelevant. It makes defining synced_clk1 difficult.
If clk1 is an unrelated external clock, setup and hold timing can't be guaranteed for the first FF. Metastable FF states must be expected with a certain likelihood. Altera design recommendations suggest a double FF sync unit in this situation.
Also if clk1 is unrelated, you should be able to find a full synchronous construct instead of the present ripple clock design.
