create clock on combo logic output
I need to create clock definition on combo logic output. What is the way to do clock definition?
I tried to add LCELL on the combo gate output and tried creating clock on LCELL.out pin. However, this did not work.
Can you please help with some way to define clock on combo logic output?
Thanks for your help!!
- FvM
although it's generally bad design practice and typically causes problems in timing closure, it's basically possible to feed a register clock port from a LCELL output. It's however not possible to feed e.g. a PLL input. What are you exactly trying to achieve?Regards
Frank
- AqidAyman_Altera
Appreciate your effort to reaching out to Intel FPGA Community.
Can you also share what device are you targeting?
Aqid
- mvkk
Hi
I am using Arria 10, 10AS066H2F34.
Creating a clock on LCELL instance output did not work for me.
Kishor
- AqidAyman_Altera
Hi Kishor,
Have you check on the documentation regarding the clocking mode in Arria 10? You can refer link below:
Aqid
- AqidAyman_Altera
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
