mvkk
3 years agocreate clock on combo logic output
I need to create clock definition on combo logic output. What is the way to do clock definition?
I tried to add LCELL on the combo gate output and tried creating clock on LCELL.out pin. How...
FvM
3 years agoHello,
although it's generally bad design practice and typically causes problems in timing closure, it's basically possible to feed a register clock port from a LCELL output. It's however not possible to feed e.g. a PLL input. What are you exactly trying to achieve?
Frank
