12 years ago
crash report
Hello, my Quartus is crashed, and I have web edition so can't find any other option to report it:
Internal Error: Sub-system: VRFX, File: /quartus/synth/vrfx/verific/database/netlist.cpp, Line: 5102
n && n->Owner() == this
Stack Trace:
    0x42e30: vrfx_altera_assert + 0x20
    0x97136: Netlist::RegisterPotentiallyFanoutFreeNet + 0x86
    0xea349: VeriNonConstVal::NetAssignFrom + 0x139
   0x16240e: VeriAlwaysConstruct::Elaborate + 0x24e
    0xd0064: VeriModule::Elaborate + 0x74
    0xd456f: VeriModule::Elaborate + 0x56f
    0x5c342: VRFX_VERIFIC_VERILOG_ELABORATOR::elaborate + 0x482
    0x5747f: VRFX_ELABORATOR::elaborate + 0xdf
    0xad8d4: SGN_FN_LIB::elaborate + 0x124
    0xb03aa: SGN_FN_LIB::start_vrf_flow + 0xa
    0xb158d: SGN_FN_LIB::start + 0x55d
    0x8301f: SGN_EXTRACTOR::single_module_extraction + 0x17f
    0x90482: SGN_EXTRACTOR::recursive_extraction + 0x192
    0x8e00e: SGN_EXTRACTOR::recurse_into_newly_extracted_netlist + 0x2de
    0x904c3: SGN_EXTRACTOR::recursive_extraction + 0x1d3
    0x93b81: SGN_EXTRACTOR::extract + 0x1b1
    0x12bb2: sgn_qic_full + 0x142
     0x464d: qsyn_execute_sgn + 0x11d
    0x1c924: QSYN_FRAMEWORK::execute_core + 0x104
    0x1f23a: QSYN_FRAMEWORK::execute + 0x26a
    0x111b7: qexe_get_tcl_sub_option + 0x1b87
    0x13ad6: qexe_process_cmdline_arguments + 0x526
    0x13bd4: qexe_standard_main + 0x84
    0x19dd6: qsyn_main + 0xa6
     0x4e21: msg_main_thread + 0x11
     0x1c98: _thr_final_wrapper + 0x8
     0x5515: msg_thread_wrapper + 0x85
     0x3921: mem_thread_wrapper + 0x31
     0x60f1: msg_exe_main + 0x81
    0x1ba1c: _main + 0x1c
    0x24cd7: __ftol2 + 0x1e1
    0x4ed5b: BaseThreadInitThunk + 0x11
    0x637ea: RtlInitializeExceptionChain + 0xee
    0x637bd: RtlInitializeExceptionChain + 0xc1
End-trace
Quartus II 32-bit Version 13.0.1 Build 232 06/12/2013 SJ Web Edition
Service Pack Installed:  1
And this is the code caused it, look around 'ribbon' object:
module VGA_HighEnd ( clk, rst,
                                iX_video, iY_video,
                                oR_video, oG_video, oB_video,
                                tumblers, endFrame, dbg_val    );
parameter RES_X_H= 1240;
parameter RES_Y_H= 1024;
parameter XY_STEP_H= 7;
parameter RES_X_L= 640;
parameter RES_Y_L= 480;
parameter XY_STEP_L= 8;
input clk;
input rst;
input signed  iX_video;
input signed  iY_video;
output reg  oR_video;
output reg  oG_video;
output reg  oB_video;
input                tumblers;
input endFrame;
output wire  dbg_val;
wire  V_out2;
wire high_res= 1;
reg  count;
wire signed  x;
wire signed  y;
assign x= (iX_video- (high_res ? RES_X_H/2 :RES_X_L/2 ));
assign y= (iY_video- (high_res ? RES_Y_H/2 :RES_Y_L/2 ));
//reg ribbon;//    NO CRASH
always@(posedge clk or posedge rst)
begin
    if ( rst )
    begin
        count= 0;
    end
    else
    begin
        if ( endFrame )
        begin
            count<= count +1;
            ribbon <=count;
        end
        //    Y'UV ->RGB
        oR_video= {7{ribbon}};
        oG_video= count;
        oB_video= -1;
    end
end
endmodule
reg ribbon;//    CRASH             !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    I can confirm your code does not crash Quartus on my machine.
    Commenting out the line you have would mean the code wouldn't parse correctly, which would mean the Analysis & Synthesis step wouldn't complete, causing Quatrus to stop earlier through the compilation. So, this would simply point at a later stage of the compilation causing the crash.
    You could report this to Altera's tech support. However, before you do that please re-install your software and see if that helps.
    Cheers,
    Alex
    Have you deleted the db and incrementaldb directories? these can sometimes cause crashes. If this and re-installing doesnt help, you will need to raise a support request.
    Well, compiling this file separately, not cause crash (internal error), indeed, but compiling whole project does. I've attached archived project now. I tested that it still crashes and I deleted db's.
    I would direct all this to tech support, but I can't find out, how web edition user could do it. And I have made a workaround, so my interest in this now purely theoretical.
