15 years ago
CPLD PFL vs NIOS FLASH Programmer
I encounter a problem to configure a EPS2180 on a custom board with the NIOS Flash Programmer.
Here is the Hardware config :
- FPGA configured at power up by a MAX2 CPLD including a PFL
- CFI Spansion 256GL 16 bits FLASH memory used to store 2 pages of .sof + NIOS .elf
- PFL option bits address is 0x0, P0 page at 0x2000, P1 page at 0x62000
- MSEL pins all fixed at GND on board (parallel programming without compression)
Now the SW config :
- Quartus 9.1 + NIOS EDS 9.1 (no SP applied)
- no firmware compression specified in Quartus
- --pfl --optionbit=0x0 specified in the script of the sof2flash utility
Results:
- Pages + option bits correctly programmed by Quartus Programmer after .sof to .pof conversion (FPGA configuration + boot of the NIOS OK)
- NIOS ELF correctly programmed by Flash Programmer
- P0 and P1 updates by NIOS Flash Programmer seems OK at the console during and after programmation (checksum control OK) but the FPGA is not configured by the CPLD at next power up (confdone doesn't rise up).
So my question :
What could be the reasons the CPLD's PFL fail to configure the FPGA after an update of the FLASH by the FLASH Programmer ?
Thanks in advance.
    It seems you're right and I'll upgrade soon to make tests !
    I just read the following in the last "Nios II Embedded Design Suite Release
    Notes and Errata" July 10 :
    Flash Programmer Errata
    This section describes in detail the Nios II EDS issues related to the flash programmer.
    Unable to Configure FPGA from Flash with Parallel Flash Loader
    If you program an FPGA image to flash memory on a board that utilizes the Parallel
    Flash Loader, the FPGA subsequently fails to load from flash memory. This issue
    arises because the sof2flash utility generates a flash file with an incompatible
    Programmer Object File (.pof) bitstream format.
    Affected Configurations
    This issue impacts the following target hardware:
    ■ The Stratix IV GX FPGA Development Kit
    ■ The Arria® II GX FPGA Development Kit
    ■ Any hardware using the Parallel Flash Loader
    Workaround
    1. Visit the MySupport website and request Nios II EDS patch 0.73.
    Alternatively, upgrade to the Nios II EDS v. 9.1 SP1 or later.
    2. Invoke sof2flash with the following options:
    ■ --pfl
    &#9632; --optionsbits=<option bit address>
    With these options, sof2flash generates a flash file with a compatible .pof file
    bitstream format.
    Solution Status : Fixed in v. 9.1 SP1 of the Nios II EDS
    The NIOS EDS patch 0.73 resolves the sof2flash issue. I attach the patch if it can help.
    After installation, there's only a warning aboout the version checking between EDS and Quartus, but il's still safe.
    Ton, thanks for your help.
