12 years agoI thought you are sending and receiving the pulse. Anyway that is another issue then. You need to send high frequency signal (On/OFF) e.g. 20 MHz or so. You need generate that from an NCO and pass i to DAC then some RF guy may help push it up to the air, receive it for you and pass it to ADC. Then you design some logic to detect the sine wave (possibly flooded with noise now). You can detect it based on some criteria e.g. amplitude threshold(and this follows gain at DAC...etc).
For an FPGA engineer, the logic part is not difficult. The RF side is.
